millers lite weight rims
minnie ub
02-04-2004 17:54:48
has anyone seen the 14 by 38 lite weight steel rims miller tire advertised before the wauseon ohio pull. wonder how much liter they are.
ChadS
02-05-2004 20:06:15
 Re: millers lite weight rims in reply to minnie ub, 02-04-2004 17:54:48
The lightest set of pressed steel rims are found on cockshutt tractors. I have a set that weigh 87# each. they have a removable bolt in center, have seen them on lots of MM pullers. I do know where there is a few sets around if you know of any one who is looking. These rims, have rivited lugs on the rim, and can be removed, and tabs be welded on in their place. Hope this helps, Chad
Jim F.
02-05-2004 13:01:49
They are still pretty heavy. They are made from the same thick centers as his regular ones. He has approx. eight cut outs that may take 20 - 25 lbs per wheel off. Maybe!
CASEPOWER
02-05-2004 20:25:35
 Re: Re: millers lite weight rims in reply to Jim F., 02-05-2004 13:01:49
He told me they are 30# lighter. Someone needs to make 1/8 or at least 3/16 instead of 1/4".
