QUESTION
DWB
02-04-2004 16:20:59
I HAVE A M FARMALL THAT HAS A ENGINE I'AM TRYING TO IDENTIFY. IT HAS A PLATE ON THE LEFT SIDE OF THE BLOCK THAT APPEARS TO BE WHERE A FUEL PUMP WOULD BOLT UP TO. ALSO HAS A PERTRUDING IN THE ENGINE CAST ON THE RIGHT SIDE THAT LOOKS LIKE WHERE A DIPSTICK COULD GO. IT HAS NO NUMBERS STINCILED INTO THE BLOCK SO I DON'T KNOW WHAT IT IS. THANKS FOR ANY HELP. ALSO WHAT DOES A HEAD WITH CASTING NUMBER 8770 MEAN. GAS,DIST/LP????? ??
Flogger
02-05-2004 08:45:06
 Re: QUESTION in reply to DWB, 02-04-2004 16:20:59
You're right is is a place for a fuel pump. I-H used these engines on the 6 series power units and they required a fuel pump. Also the service blocks from I-H for the tractors and power units came with the with the fuel pump mount so your block could be either one. There should be some casting #s on the RH side above the tappet cover, firing order, date, etc.
The 8777 head is a kerosene head.
DWB
02-06-2004 19:51:38
 Re: Re: QUESTION in reply to Flogger, 02-05-2004 08:45:06
THANKS FOR THE INFO. BECAUSE I HAD NO IDEA WHAT IT WAS,
