P-Pump??
puller
02-03-2004 18:49:01
what is so good about the pump over the 450 roosamaster? what did these come on? thanks alot
Redman
02-04-2004 23:39:25
 Re: P-Pump?? in reply to puller, 02-03-2004 18:49:01
the roosamaster is a good pump but it won't take rpms or put out the fuel to match a P series inline.the P is consistant with RPM range to near 7000 and are not near as fussy as a rosy.superfarm is the only class that really runs them in the ntpa anymore,but they are a good pump and dollar for dollar a better deal than the prostock and superstock pumps.if you want one for a red tractor you have to find one off a ih bulldozer of the 70s for deere i think they were on the 8650s and construction equipment.a deere pump will work on the ih but the lines will be mixed because the firing order is different.
The Swami
02-04-2004 12:20:16
The Roosa will only safely get around 300 to 350 cc's of fuel, I've heard of some being higher, but have not actually seen them. The P pump can be worked to go over 1000 cc's of fuel, plus, they will handle the high rpms, 5000 to 7000, the Roosa will start twisting shafts and seizing heads around 4000 usually. The roosa is good for farm and hot stock, if you want to go superstock, superfarm, etc. get an inline pump.
WTW
02-04-2004 07:59:31
The 450 will get you in the neighbor hood of 300cc of fuel delivery. The "P" with the right mods will take you over 500 cc and more. Its all how much you want and need.
G-MAN
02-04-2004 07:41:50
If it's the same "P" pump I've been around, it refers to a Bosch P7100 inline pump. They're usually found on higher horsepower tractors and engines, and have big pumping elements and a lot of fuel delivery capacity. They can be modified to inject a BUNCH of fuel.
BigART
02-04-2004 17:14:02
 Re: Re: P-Pump?? in reply to G-MAN, 02-04-2004 07:41:50
Hihp pullers tell me the p-pump is more reliable than either an a in-line or the hopped up roosamaster or IH pumps; little ones can be built to 500cc's, but only last one season.
G-MAN
02-05-2004 07:43:54
 Re: Re: Re: P-Pump?? in reply to BigART, 02-04-2004 17:14:02
I've been around a lot of "P"s on stock engines, and they seem to be a heck of a pump all the way around. It's hard to outdo Bosch in the fuel injection game. They've been at it a LONG time.
4620 Deere
02-05-2004 13:29:59
 Re: Re: Re: Re: P-Pump?? in reply to G-MAN, 02-05-2004 07:43:54
Will the P pump fit on the late model 404's of the John Deere 4520/4620?
The Swami
02-05-2004 16:17:06
 Re: Re: Re: Re: Re: P-Pump?? in reply to 4620 Deere, 02-05-2004 13:29:59
No, a P pump will not fit the original motor, you have to put in the newer motor with the front driven pumps.
