560
Red Boy
02-02-2004 18:24:31
I have a good 560D block (old style) it has good sleves in it but I am building it to pull with. So I would like to bore it 30 over and still have sleves in it. I can get it bored but i dont know where to get pistons and rings from. Any advise would be helpful.
E J
02-02-2004 19:02:29
 Re: 560 in reply to Red Boy , 02-02-2004 18:24:31
Just fill the gap with a piston ring
JJ
02-02-2004 18:44:29
pull the sleeves out get a set of pistons for 301 diesel 503 combine or 60's model truck motor. works real well and not that expencive.
Red Boy
02-02-2004 18:56:52
 Re: Re: 560 in reply to JJ, 02-02-2004 18:44:29
I cant pull the sleeves out because the old style blocks have the extra large groove at the top where the sleeves sit in. But the newer blocks are not that way.
farmall
02-03-2004 09:02:25
 Re: Re: Re: 560 in reply to Red Boy , 02-02-2004 18:56:52
I MAKE STEEL RINGS TO FILL IN THE GAP. wORKS WELL
GIVE THEM A SLIGHT PRESS. i LEAVE MINE PROTRUDE ABOVE HEAD ABOUT .005" TO BITE INTO HEAD GASKET. HOPE THIS HELPS.
JJ
02-03-2004 14:52:40
 Re: Re: Re: Re: 560 in reply to farmall, 02-03-2004 09:02:25
your on the right track. measrure a old head gasket. let the ring protrud with in 3-4 thosandth of that distance. won't have to worry about blowin head gaskets.expecaly if you use a copper , make hole for clynder snug fit on outher side of ring.
