Farmall H aluminum parts
Farm w/Junk
02-02-2004 14:33:40
Hi I am thinking of making a H pulling tractor and heard there are aluminun decks for under the seat to lighten them up. Is this true? Where to get and how much? Also will removing pto and belly pump and belt pulley drop much weight? Thanks
Matt
TimC
02-03-2004 13:48:20
 Re: Farmall H aluminum parts in reply to Farm w/Junk, 02-02-2004 14:33:40
A friend of mine was quoted 1500.00.
farmall
02-02-2004 15:37:02
Brad Begamen has an add in the Hook Mag. He is building top covers for 'M's currently. I have also seen pullers cut off top cover just behind shifter and use a aluminum plate. Removing PTO, Belt pully & Hydraulic pump will loose a bunch of weight. Hope this helps
W.R.
02-03-2004 13:58:23
 Re: Re: Farmall H aluminum parts in reply to farmall, 02-02-2004 15:37:02
ordered one from him at Hartford, Ky pull for M, $500,
