unstyled A rocker arms
Jd Puller
02-01-2004 19:55:00
has anybody ever tried to pressure oil the rocker arms on an unstyled A.....I am thinking of trying and would liketo know your comments.
A puller
02-03-2004 08:01:59
 Re: unstyled A rocker arms in reply to Jd Puller, 02-01-2004 19:55:00
I changed my 36 to pressure type oiling like the later styled ones. You need to run an oil line from the pump up thropugh the oil return cavity in the bottom of the block. Then tee it inside the valve cover and run it out to the intake rockers. You need to pinch the tubing off and drill a small hole over the rocker. This worked good for us kinda tight under the valve cover but ther is room. Only run the oil to the intake rockers it will flow down the rocker shaft to the exhaust. Hope this helps and good luck.
