Wet Sleeve Over Bore?
Out Classed
02-01-2004 06:18:44
Has anyone had an IH C123 block bored to fit C135 sleeves/pistons? Do the C135 piston pins fit the original C123 rods? Is the deck height correct? Any help would be GREATLY appreciated! Thank you!
Shaggy
02-01-2004 08:21:30
 Re: Wet Sleeve Over Bore? in reply to Out Classed, 02-01-2004 06:18:44
If this is the same as the stuff I have (AorB) The hole on the bottom is of the block is 3 5/16 for the 3 1/8 bore sleeve and for the 3 1/4 it's 3 7/16. Geneb on the farmall page told me you can have the sleeve turned down to fit the block. My Father and I have had the bottom of the block bored out but we had a rough time finding a thin enough O-ring to fit in the groove. If you are going to a bigger bore than 31/4 get with Chads he will get you going in the right direction.
