horsepower
joe
02-01-2004 03:56:01
ok if you have your tractor setup just right and then you do some work on the engine and get 10 more horse power . and now you spin out with the extra power how do you get it to the ground?
FB
02-01-2004 13:06:36
 Re: horsepower in reply to joe, 02-01-2004 03:56:01
Turn you RPM's down
EFV
02-01-2004 05:39:05
1) Change final drive ratio. Taller tires,faster gears,whatever. Added power lets you go faster. Increase in speed helps nose heavy tractors by transfering load to rear wheels.
2)Change chassis setup so more weight is on rear wheels.The slower you go the more static weight must be on rearend. Tractor was "just right" before so changing air pressure probably won't be needed.Tire tread may need improving-cutting
or pattern change(45 degree to 23 degree).Wider tires may be useful.
3) Check your notes.You do keep track of your performance as well as the competition's,don't you? Many pullers do it mentally,written is better. Weather,track conditions,anything and everything.Videotaping is an excellent way to document what happened. You can be surprised at what you find out watching tapes. The camera does not lie.
52 A Boy
02-01-2004 05:18:53
1. You could go up to another weight class and put more weight on it.
2. You could put a size bigger tires on it if you can, check your clubs rules and see how big you can go in your classes.
3. You might try a higher gear in the light classes.
4. Let out more air in your tires depending on the track cond.
Just some ideas
52 A Boy
BUD BATRNIE
02-01-2004 15:16:05
 Re: Re: horsepower in reply to 52 A Boy, 02-01-2004 05:18:53
WHAT GEAR WERE YOU PULLING BEFORE, DID YOU BLOW THE TIRES OUT ON MULTIPLE PULLES AND IN HEAVIER CLASSES. DID YOU BLOW RIGHT SIDE TIRE OR BOTH ~!~
DID YOU CHECK YOUR FOOT PRINT DURING THE PULL TO SEE IF IT WAS FLAT-CONCAVE OR CONVEX,
DID THE MOTOR LOSE ANY RPMS. DID IT LUG AT ALL .
DID YOU PULL THE FRONT END. WAS THE HITCH SET RITE
BEFORE YOU PANIC, PAY ATTENTION TO ALL DETAILS. YOU NEED TO RUN 23 DEGREE BARS 10HP SHOULD HAVE HELPED MORE THAN EVER HURTING!!!
JUST DROP THE HAMMER AND FIND A GOOD LINE !@!!
MY OPINION SIR PULLING FIRST GEAR STOCK CLASS THOUGHT A HAD A BIG MOTOR UNTIL I FOUND A GREAT PAIR OF TIRES, I JUST NEED 10HP
