Need advice on a motor for a allis wd
rk
01-31-2004 13:11:15
I WAS LOOKING FOR SOME ADVICE ON BUILDING A MOTOR FOR MY WD I PULL BOTH TRANSFER SLED AND STONE BOAT AND NEED A ENGINE THAT WILL HOLD UP TO BOTH ANY INPUT WOULD BE GREAT THANKS
JH
02-01-2004 20:12:03
 Re: Need advice on a motor for a allis wd in reply to rk, 01-31-2004 13:11:15
call TNT machine shop Polo, mo 816 586 3901
Allis
02-01-2004 10:36:02
a set of leroi rods will go on the crank or a 45 crank, use 4 1/8 sleeves and find a set of short automotive pistons to get the comp 8 to 9 to 1. Clark copper gaskets can make a head gasket up to .093 thick with any bore size if need be some mild head porting and a cam around 210 -215 duration would make a tough economical motor with the ability to run stock rpm classes or would rev up when the rules would allow it. Rocker arms from a 361-407 international engine will fit and give a better ratio but will have to be bushed to fit an allis shaft. This is just a cheep and simple bolt togather combo with minimal work and $$ for the power gained
Chuckster
02-01-2004 08:53:39
Heres a few things that ive done to mine.First thing if your going to rebuild your motor is put a 45 crank in it and do a little porting and polishing to the head and put electronic ignition in it and you can still run pump gas. My freind and I had a ball with it last season.I hope this helps good luck!!
