MSD IGNITION
zig
01-31-2004 12:55:27
Is it worth the money and does it help and what changes do you have to make timeing carbortor ex thanks
ChadS
01-31-2004 14:01:18
 Re: MSD IGNITION in reply to zig, 01-31-2004 12:55:27
I used to belive that they were worthless. I learned recently, that I was wrong. With the help of TimC, and a few good freinds, I learned where I went wrong. I left in the condensor in the distributor. The MSD, is triggered by points, and changes the wave pattern of the tradional spark. I installed a MSD6AL on my 460H, and I have noticed a big difference in the way it starts, Idles, and at high rpm, where I had a slight miss, It cured it. Get one, or any kind of aftermarket ignition system, it will help. Just my 2 cents, Chad
zig
01-31-2004 17:22:32
 Re: Re: MSD IGNITION in reply to ChadS, 01-31-2004 14:01:18
chad what did you run for plugs
ChadS
01-31-2004 19:49:10
 Re: Re: Re: MSD IGNITION in reply to zig, 01-31-2004 17:22:32
Well after getting the igntion hooked up, the plugs needed to be swaped out, I put in Champion 4130 truck plug in it, Chad
Hillbilly Hooker
02-01-2004 20:34:49
 Re: Re: Re: Re: MSD IGNITION in reply to ChadS, 01-31-2004 19:49:10
Loose the champions and use AC. I have much better results with them than the champions. Just my pennys worth. H.H.
ChadS
02-02-2004 07:17:56
 Re: Re: Re: Re: Re: MSD IGNITION in reply to Hillbilly Hooker, 02-01-2004 20:34:49
I agree about losing the avarage Champion plug. These are not the everyday champion plug. I used AC in all of my tractors, and some still do,, but my stroker engines have the champs in them,, just go to the store, and look at one,, you may be surprized!! How is the big Moline? Seen a GIV down in KY for sale, in the paper, 1400 dollars. Chad
02-02-2004 19:16:11
 Re: Re: Re: Re: Re: Re: MSD IGNITION in reply to ChadS, 02-02-2004 07:17:56
Are these plugs colder or hotter than a D15?
ChadS
02-02-2004 21:04:41
 Re: Re: Re: Re: Re: Re: Re: MSD IGNITION in reply to ?, 02-02-2004 19:16:11
Hotter, the electrode on them is about 3/4 of an inch below the threads. longer than the d series plugs, different core material conductor, Chad
