No oil pressure on WC
Keith
01-31-2004 11:59:11
We fired up the WC after a rebuild. We had no oil pressure but there was an oil leak. We found out that there was a freeze plug (or something similar to it) that covers the end of the cam shaft under the bell housing. We pulled the engine to replace this and while it was out, replaced the oil pump and made sure that all of the lines were clean. we are thinking that the oil releive valve is causing trouble. The I&T manual says that oil pressure can be varied by adding or removing shims. I am not sure what we need to do. Can anyone please make a recommendation? Has this ever happened to you?
Thanks,
Keith
Captainhookerus
01-31-2004 20:20:49
 Re: No oil pressure on WC in reply to Keith, 01-31-2004 11:59:11
If you did as the overhaul manual says, you remove the plugs from both ends of camshaft and clean inside of camshaft. Then check to make sure you put the plugs back in. Since you blew out rear soft plug it sounds as if you are getting full oil pressure and flow to rear soft plug. The rear drain hole cannot drain fast enough and 20 lbs of oil pressure will blow plug.
Ken
Andy
01-31-2004 16:38:18
you dan shim the oil presure relief valve, it is on the left side of motor down near the pan line look like a sarge bolt head , add a washer behind the spring to increse psi. The oil filter housing must have a 1/4 tube sticking up inside about 3 to 4" it sticks in the center of the filter. you need a oil filter with a cloth filter element not paper I made the same mistake on my WC. I went as far as to replace the bearings
didnt help, put a Hastings oil filter on and had all kinds of psi. some filters come with a stick in them pull it out, that is where the tube in the housing goes hope this helps.
dan
01-31-2004 15:08:09
did you remember the plunger in the front of the cam? i've seen alot of ac's with little or no oil pressure but the front cover got plenty of oil after a rebuild.
Jeremy
01-31-2004 12:23:24
Keith, alot of times, the oil filter is not right on the allis chalmers. I know Napa had trouble with this. Theoriginal oil filter has a wooden stick the goes in it. if this is missing, there will be no oil pressure. Ading and removing shims is in the oil filter housing, or it maybe in the side of the block next to the filter housing. Tis will raise or lower the oil pressure, which should be 10-15 psi at an idle. Hope it helps.Emailme with any other problems
Jeremy
Keith
02-01-2004 04:27:45
 Re: Re: No oil pressure on WC in reply to Jeremy , 01-31-2004 12:23:24
Thanks for all of the help guys. It ended up being the guage. It was new but didn't work. I pulled one off of a Farmall and it showed some pressure.
Thanks,
Keith
