Oliver motor/rule question
Jim
01-30-2004 19:08:32
When rules say the motor must be same manufacturer as frame, what do they mean? And is a 1755/283 or 310 considered a 7 bolt main????
TimC
01-31-2004 18:26:28
 Re: Oliver motor/rule question in reply to Jim, 01-30-2004 19:08:32
Has to also be same length. So if you can machine the front or rear to be the same length as an 88 engine it is legal.
corndog
01-31-2004 20:54:13
 Re: Re: Oliver motor/rule question in reply to TimC, 01-31-2004 18:26:28
there are 738 thousands differance bolt in the same bolt holes and has the same apperance.
TimC
02-01-2004 19:25:20
 Re: Re: Re: Oliver motor/rule question in reply to corndog, 01-31-2004 20:54:13
.738 to long.
bigdeal
02-01-2004 20:37:37
 Re: Re: Re: Re: Oliver motor/rule question in reply to TimC, 02-01-2004 19:25:20
bet you can't tell with out reading the ##'s on the block.
TimC
02-02-2004 06:48:39
 Re: Re: Re: Re: Re: Oliver motor/rule question in reply to bigdeal, 02-01-2004 20:37:37
If it still have the 12 port head then its a dead give away.
Jim
02-02-2004 18:20:57
 Re: Re: Re: Re: Re: Re: Oliver motor/rule question in reply to TimC, 02-02-2004 06:48:39
It still has the 1755 manifold, I had to cut a new hole in the hood.
corndog
01-31-2004 17:49:02
A friends past experience with natpa, they would not let him run a 88 motor in a 77 frame in div..V but they will let you run a 77 rearend on a 88 tub and sheetmetel. or a 7 bolt motor in a 88 div.V whats the differance?
Jeff
01-30-2004 19:56:47
Looks to me as it it means you can take the motro out of an Oliver 1850 and shoehorn it into a 77 or 88 frame if you want to. Wonder if that means an 806 motor in a M ?? Hehe of course techically i don't see how an Oliver could run with those rules since Oliver cast the frame and Waukesha built the motors!!! LOL!!! I am allowed to pick on Olivers since i pull one also. Not sure about the 7 bold main though.
Jim
01-31-2004 12:12:44
 Re: Re: Oliver motor/rule question in reply to Jeff, 01-30-2004 19:56:47
I agree with you, but what about a continental motor in a massey harris. Massey Harris casts the frame and continental made motors for many companies. So that frame rule is not specific. I take that rule that I cant run a 283 in my 88, but some people say I can.
Cody
01-30-2004 21:15:54
Yes they are 7 main motors. I have a complete 1550 gas engine if interested. 55 hp. stock
