88 or 880 oliver-wheelie bars
J.
01-30-2004 07:36:57
Can someone tell me an easy way to put good wheelie bars on an 88 or 880. I've got the shorter hitch made, but just need to get my wheelie bars done. only pulling 3mph class. Thanks
J.
01-30-2004 14:54:23
 Re: 88 or 880 oliver-wheelie bars in reply to J., 01-30-2004 07:36:57
Does anyone have any pictures they would send me of some good wheelie bars. It would be some trouble but I would appreciate it.
Jeff
01-30-2004 19:52:30
 Re: Re: 88 or 880 oliver-wheelie bars in reply to J., 01-30-2004 14:54:23
I'll try to go up and get some pics of mine Saturday and send them to you if you will semd me an email address. I used square tubing and welded angle on for top and bottom of the axle then still had to weld some brackets on the sides to hit the angle of the axle. They must work as I picked the tractor up with the back wheels off the goround about 6 inches and they never moved.
TimC
01-30-2004 09:20:58
Square tubing from axle housing back to pads. One high and one low brought together at the bottom where the skid pad is welded on. Slot the tubing and weld in metal plates that have bolt hols to mount to axle housing. Then weld in an upper and lower cross peice of tubing to tie them together.
