block sealer
Ryan
01-29-2004 18:40:17
does any one know what i could use to seal my block after my sleeves have been put in. i want something that i can pour in though the top of the block that will be runny, and when it drys i would like something thats a somewhat rubbery. i don't want to use hard block so if any one has any other suggestions let me know.
thanks
TimC
01-30-2004 06:47:38
 Re: block sealer in reply to Ryan, 01-29-2004 18:40:17
Do you just need to seal the bottom side. Are the sleeves aftermarket w/o orings? Are they press fit. Hard block stabilizes the sleeves. Thats a good thing but you sound like you are trying to seal the water in. How does the bottom of the sleeve interface with the bottom of the block.
Mike Aylward
01-29-2004 18:45:50
Ryan, a machine shop that is doing some work for me is going to use an epoxy product for this very reason. They say it is much better than hard block. Mike
Ryan
01-29-2004 18:59:34
 Re: Re: block sealer in reply to Mike Aylward, 01-29-2004 18:45:50
Mike, could you get me the name of the epoxy that you are going to use
Thanks
Mike Aylward
01-29-2004 19:29:35
 Re: Re: Re: block sealer in reply to Ryan, 01-29-2004 18:59:34
Ryan, I will try to do so. I imagine any competent machine shop would know what this product is. But I will check. Mike
Mike Aylward
01-31-2004 13:19:21
 Re: Re: Re: Re: block sealer in reply to Mike Aylward, 01-29-2004 19:29:35
Ryan, I just checked Murphy's Motor Service's website (where I am getting some machine work done) and he now is listing this product. It is called "Blockpoxy". You can check it out at his website. Mike
