Rocker arm ratio on John Deere G ?
JD720
01-29-2004 17:08:57
I have been looking at the aluminum roller rockers that are made by murphy`s in Mo. They are a 2 to 1 ratio. Does anyone know what the stock ratio is ? I believe this should be taken into consideration when I get the cam reground.Any help is appreciated.
Dennis Andres
01-29-2004 20:26:21
 Re: Rocker arm ratio on John Deere G ? in reply to JD720, 01-29-2004 17:08:57
Check out Murphy's Motor Service Web Site.If it don't give you the stock ratio he has an E-mail address on the webpage,I think he will give you the info.My 60 jd has 1.5 ratio stock and his roller rockers are 2 to 1 ratio.It added 7 hp to my stock engine but I lost some bottom end torque.
puller
01-30-2004 09:46:24
 Re: Re: Rocker arm ratio on John Deere G ? in reply to Dennis Andres, 01-29-2004 20:26:21
Dennis
That is quite a increase in power. Not to make you mad or nothing but did you test your 60 on a dyno before and after?
I have wondered too if a 2.0 ratio would make any more power on a stock motor but no one will say or they don't know how much.
I have asked Murphy's if it will make more power on a G with a overbore and head work, they couldn't tell me.
If they make as much power as you say, maybe I better get a set.
Dennis Andres
01-30-2004 19:39:15
 Re: Re: Re: Rocker arm ratio on John Deere G ? in reply to puller, 01-30-2004 09:46:24
I checked it before and after on an M&W pto dyno.I do have std. bore aluminum pistons at 135 psi compression with solid state ignition,but I had that setup before the rockers.
Jonathan
01-30-2004 12:22:29
I dyno'd my G before and after with 2.0 ratio rockers with 125 over pistons and 6.5 to 1 compression. I made 5 hp difference with roller rockers. Then I went and up'd the compression to 9.5 to 1 and had the cam ground. That increased the hp by 10hp but it is very hard to start. To much valve over lap now with the rockers and cam. But once it starts it runs like a clock. Just my two cents.
buickanddeere...improved
01-31-2004 15:09:19
 Re: Re: Re: Re: Rocker arm ratio on John Deere G ? in reply to Jonathan, 01-30-2004 12:22:29
The beauty of changing just the rocker arms to high ratio rollers are. Less valve train friction and more valve opening with the same cam duration. And the engine doesn't have to be opened up all the way back to the cam. Torque will be increased across the entire rpm range and no loss of low rpm torque like a too hot cam will.
buickanddeere
01-31-2004 15:08:20
The beauty of changing just the rocker arms to high ratio rollers are. Less valve train friction and more valve opening with the same cam duration. And the engine doesn't have to be opened up all the way back to the cam. Torque will be increased across the entire rpm range and no low of low rpm toque like a too hot cam will.
Johndeere_john
01-30-2004 16:15:35
What is the ratio on the stock rocker arms?
Jonathan
01-31-2004 14:25:04
 Re: Re: Re: Re: Re: Rocker arm ratio on John Deere in reply to Johndeere_john, 01-30-2004 16:15:35
Stock ratio is 1.5 to 1 on a 52 G.
Tyler Neff
01-30-2004 19:11:10
I would also like to know the stock ratio. Nobody seems to know . I cant see those rockers (roller) making that much of a difference seeing as to how low the RPMs are, however I also believe that JD rocker arm are very sloppy and if you have them cut Ive noticed on mine that the push rods seem to bind up. I think the roller rockers are a nice addition to any tractor, but I dont think they are the HP miracle part. I think they would allow the engine to run better performance wise but dont expect 15HP.
Drew
01-31-2004 11:52:07
 Re: Re: Re: Re: Re: Re: Rocker arm ratio on John D in reply to Tyler Neff, 01-30-2004 19:11:10
You might be suprised on how much they help. On our modified A engine, they made 12 HP.
