looking for big hp in Farmall M that can turn Lots
Puller
01-29-2004 10:44:04
I would like to bore,strok,camed,all of the goodies to get lots of hp but it has to stay together and turn some rpms and combination ideas?
thanks to all C puller
Wild Horses
01-30-2004 10:18:28
 Re: looking for big hp in Farmall M that can turn in reply to Puller, 01-29-2004 10:44:04
You guys who know correct me if i'm wrong, but the secret to getting a motor to hold together at HIGHER than rated RPM is balancing. You can't have the thing shaking itself apart.
As for bore & stroke, we have a few 407 cu in. M's around here. ?? x 7 1/2. I've heard of 4 1/2" bore. Mine's 4.3125 (4 5/16), stock stroke though. Heard of guys offsetting the bores to make room also. Never heard of any more stoke than 7 1/2 though.
farmall
01-30-2004 11:23:55
 Re: Re: looking for big hp in Farmall M that can t in reply to Wild Horses, 01-30-2004 10:18:28
I am running 7.75 stroke in mine. Wont run over 2200 rpm's though.
FB
01-30-2004 14:28:31
 Re: Re: Re: looking for big hp in Farmall M that c in reply to farmall, 01-30-2004 11:23:55
have heard of 5 1/4 by 8in stroke....don't know if it exsists though
1206SWMO
01-30-2004 09:11:19
Back in the late 1960's a puller by the name of Gene Biddle from Owensboro,KY pulled a 5000 lb M Farmall called Super Chicken.It had headers,4 bbl carb,flat turned some rpms,and sounded sweet.I saw it pull at the 1969 M&W pull.I have no idea on the bore and stroke.
francis
01-29-2004 21:07:43
maybe go 5 1/16 bore x 8.5 stroke. That should be a good high RPM turning engine! Use ethanol mix (like CHADS) and get his special governor spring! You're set then! Just my .02 cents
Go or Blow
01-30-2004 05:48:38
 Re: Re: looking for big hp in Farmall M that can t in reply to francis, 01-29-2004 21:07:43
Hey Francis, your idea sounds too ambitious for a M. Doubt that combo would stay together at high rpm.
With respect,
GB
farmall
01-29-2004 14:29:10
Your wanting your cake and eat it too! Long stroke and high RPM's are hard to come by. What RPM'S are you talking? How many cubes? What class are you wanting to pull?
WILDMAN
01-30-2004 07:38:15
 Re: Re: looking for big hp in Farmall M that can t in reply to farmall, 01-29-2004 14:29:10
HOW MANY R'S ARE YOU WANTING TO TURN?
puller
02-02-2004 08:51:25
 Re: Re: Re: looking for big hp in Farmall M that c in reply to WILDMAN, 01-30-2004 07:38:15
maby then I am just looking for the biggest bore you can put in a M maby stroke it a little if any I would just like to wire the govener so it will scream.
farmall
02-02-2004 11:05:21
 Re: Re: Re: Re: looking for big hp in Farmall M th in reply to puller, 02-02-2004 08:51:25
You sound dangerous! Be careful and have fun.
