W-9 Front Hub changeover
Texas Red
10-25-2001 06:04:21
I want to lower the front end of my W-9. will the hubs off an M Farmall fit, any changes in barrings? If this will not work , does anyone know how to lower the front of this tractor? Thanks for any Help you can give. TR
Been there
11-04-2001 06:09:25
 Re: W-9 Front Hub changeover in reply to Texas Red, 10-25-2001 06:04:21
I put F-30 16-inch spoke wheels on my W-9. They required different tapered bearings and a spacer as the W-9 spindle is pretty long and a little bigger than the F-30. This wasn't too big a deal, though, and they're definitely lighter than those 18-inch cast ones. Hope this helps.
obvious answer
10-25-2001 06:27:56
Smaller front tires
KB
10-25-2001 17:02:04
 Re: Re: W-9 Front Hub changeover in reply to obvious answer, 10-25-2001 06:27:56
What size are the W-9's and what size are on the M? The answer may not be too obvious, as an M had 16 inch wheels compared to the 18 in wheels on a W9.
I can't answer your question. Obvious answer is correct in what you have to do, but does he have a clue and help-answers you asked. Obviously not.
Sorry, I have gotten fed up with some peoples less than helpful thoughts on this and other sites.
Chuck
01-21-2002 21:48:08
 Re: Re: Re: W-9 Front Hub changeover in reply to KB, 10-25-2001 17:02:04
Find a front end off of a W-6 or W-4.
