Stroking a F-20 Crank
Todd
01-28-2004 13:31:23
Does anyone know of a good place near Sioux Falls SD to stroke a Farmall f-20 crankshaft? Also would anyone be willing to share their trade secerts in building a F-20. We already have the plan laid out for it but would still like to hear what others have done. Thanks for the help
F20 BAD CHOICE
01-29-2004 15:59:48
 Re: Stroking a F-20 Crank in reply to Todd , 01-28-2004 13:31:23
Low RPM to start with, very poor engine design. You would be better off restoring it for a collector piece. There are much better tractors available. I would keep looking
lots of work, lots of fun
01-28-2004 16:33:37
If you are going to do the F-20 crank, you better consider building a center main to support it. I know of 2 that have been done for 10-20 engines. Basically they had to do a ton of welding to build up the center of the crank that could be turned down to a journal. Next you have to fabricate a main the is split in half. Then you position it in the block and bolt it through the side of the crankcase. Lot of work, but I think you can get a 7.75" to 8" crank to hold up that way.
farmall
01-28-2004 13:56:48
Are you sure you want to build a F20? With two main brg's. they are a poor canadate. My friend pulls one and crank wont last a year. He has 7" stroke with 4.25 bore. Around 90 HP. This is not strong enough for div 3 tractor & geared to fast for div 2. My suggestion is to look at something with a center main. He is running a 560 IH rod brg.
