Need to switch the pulley setup in a 48' A
Matt
01-28-2004 08:40:05
I want to know exactly what I need in order to slow down my 48' JD A. I know I need the pulley from a late model A, but what gears and so on do I need. Thanks
Jim
01-30-2004 07:53:15
 Re: Need to switch the pulley setup in a 48' A in reply to Matt, 01-28-2004 08:40:05
I changed the reduction gears on my 47A-like they said no big deal,but--the clutch assembly from a latter A is a better design----if it is possible get all the parts for the clutch assembly, if you can----the T bolts are thicker-and the plate is pinned insted of loose like the 48A also the clutch disc is thicker and the T bolts are longer---changing the reduction gears too a late (straight stick 6 speed trans.)will slow you down 1/4mph...----- -good luck...
Big Jugs
01-28-2004 11:37:40
Matt, you don't need the whole pulley. Just the first reduction gear and the gear from the back of the pulley to match. But you must change BOTH. The gear on the back is just pressed on, some heat and a gear puller will take care of this, and you will save some dollars.
matt
01-28-2004 11:50:22
 Re: Re: Need to switch the pulley setup in a 48' A in reply to Big Jugs, 01-28-2004 11:37:40
Where exactly is the first reduction gear located. I know of the one that is on the back side of the pulley.
Big Jugs
01-28-2004 13:09:22
 Re: Re: Re: Need to switch the pulley setup in a 4 in reply to matt, 01-28-2004 11:50:22
The first reduction gear is driven by the gear on the back of the pulley. You have to remove pulley assembly, right brake assembly, and then the big reduction cover. You may have to remove rear right wheel if you don't have enough room to slide pulley out. That's all there is to it. If you have never done it, it is about a maybe 3 hr job, if all goes well. Not a complicated job, just time.
Eric
01-29-2004 04:23:17
 Re: Re: Re: Re: Need to switch the pulley setup in in reply to Big Jugs, 01-28-2004 13:09:22
Don't forget that the reduction gear has to have the splined hub and not the keyed hub.
