U.S.A.P Question?
Jack
01-27-2004 14:31:09
Heard something the other day that U.S.A.P was going to let cut tires into the farm stock classes,is this true or is somebody blowin smoke?Thanks
ray raymond
01-27-2004 14:52:12
 Re: U.S.A.P Question? in reply to Jack, 01-27-2004 14:31:09
the ruling that has been explained at the drivers meeting that you can slope the back side only no front cut at all. any cut in the body of the tire( in between the treads) will be considered a cut tire. seems some had been spinning the tires backward on contrete or metal grating and had caused the guys to not be able to determine wether they were cut or not. to stop the problem John said o.k. its legal to shape the backside. check his web site www.usapuller.com on the news section i think in july or aug post.
Jeff
01-27-2004 14:55:56
 Re: Re: U.S.A.P Question? in reply to ray raymond, 01-27-2004 14:52:12
So that wording would mean that as long as you keep the grind marks on the back of the tread then you can take a set that is about 60% and grind them down to about 20% or less with a good sharp edge. Did I read that right? as long as there is no grind marks between the treads..
DOESN'T MAKE SENSE !!!
01-27-2004 16:33:23
 Re: Re: Re: U.S.A.P Question? in reply to Jeff, 01-27-2004 14:55:56
yes your correct, seems silly to allow that kind of tire work in a "farm" class. now all the weaker 4 mph tractors are on the super farm classes because thats where the $$$ are. over fifty tractors in the 5500 sf in NOV. less than 18 in the 4 mph class if i remember correctly. mostly same tractors, just seem to be a lot of floating to the super farm classes. What happened to the big idea from last year about making the super farm more stock? (looking at the size of the front tires etc, ??) don't suppose that is very important in a class that allows cutting the tire..... ....
Jack
01-28-2004 14:24:20
 Re: Re: Re: Re: U.S.A.P Question? in reply to DOESN'T MAKE SENSE !!!, 01-27-2004 16:33:23
I don't usually pull U.S.A.P.but if I did I would want my tires to be as competitive as the rest,trouble is will the other pulling organizations follow suit?Just wouldn't want to do some cutting and get rejected from other clubs.
