Johnson LP intake
Donnie
01-27-2004 13:09:00
Where or who sells these intakes? And will the Johnson Intake work with my exhaust manifold? I'm putting it on a M farmall. I have the old ones cut apart already. Thanks for the help.
farmall
01-27-2004 16:07:00
 Re: Johnson LP intake in reply to Donnie, 01-27-2004 13:09:00
You can purchase one from Hank Steel #231-584-3322
or cell #586-405-6270. He has both intake & exhaust manifolds. And yes you can use just the intake manifold. You need to look at the exhaust manifold though, it is a very nice piece and excepts a 3" exhaust pipe. Very little porting of manifold is required. Hope this helps Farmall
Flogger
01-28-2004 14:09:27
 Re: Re: Johnson LP intake in reply to farmall, 01-27-2004 16:07:00
Is there any HP advantage with the Johnson manifold as compared to a 450 LP?
farmall
01-28-2004 14:31:35
 Re: Re: Re: Johnson LP intake in reply to Flogger, 01-28-2004 14:09:27
The intake is better I think because it's a 'Y' instead of a 'T'. I run a johnson intake & exhaust on my div 4 'M'. Part of last year I was running a header (that I made) and NATPA made me get rid of it. It now runs better with the johnson manifolds on. This is in part because the castings are thick enough to make them bigger. The header tubing is thin and can not be made bigger were needed. The header would work good if you made the intake runners tapered to accelarate the intake charge. Bang for the buck & being NATPA legal is were the johnson shines. Hope this helps
Dave
01-28-2004 13:00:32
What amout of $$$$$ are they asking for these manifolds???
farmall
01-28-2004 14:04:08
 Re: Re: Re: Johnson LP intake in reply to Dave, 01-28-2004 13:00:32
The intake & exhaust are $162.50 each or $325.00 a set. They are high quality castings made from ductile iron. I've seen them and look very good.
Hank will have some manifolds at Princeton, Akron & Columbia NATPA pulls
Hope this helps
Farmall
