Need more traction for my 460d.
jason b.
01-27-2004 10:51:59
I have a 1960 farmall 460 diesel. The tractor has plenty of power but just doesent have the traction it needs. I am going to be pulling it in the summer just at a few local pulls. It has 14.9-38's that are bolth new and are loaded. I plan on pulling farm stock in probly the 7,500-8,500 class's. What kind of air pressure should i have should i unload them or load them. the tractor has a wide front so its pretty heavy. And i really dont want to lighten it up to much because it gets used on the farm also. Any suggestions? Thanks.
Farmall Daddy
01-28-2004 06:05:59
 Re: Need more traction for my 460d. in reply to jason b., 01-27-2004 10:51:59
I pull a Farmall 560 gas, narrow front in the 7500-8500, and the 8500-10000 at local pulls. I use mine around the farm too. I have my back tires loaded with calcium chloride, and my front tires have it in the too. Do you have a fast hitch, or a straight drawbar on it? I have a fasthitch on my, and I have to lock my hitch in place with the arm's that come off of the raising lever. I then set my hitch at 18 inch, or the maximum. It sounds as if you are nose heavy with your wide front. In the 10000 pound class, I run 640 pounds of weight on the front, and the front end comes off the ground about 4-5 inches. I have a set of wheel weights hanging off the bell housing in the holes next to the hydrolic pump filter plate, one on each side. Then I have 4 wheel weights on each wheel {1200 on both tires}, wheelie bars on the axel both holding 2 90 pound massey ferguson suitcase weights. I run 4 of them on the back so if I need some on the front, I move 2 of them onto the front. She will pull good the way that I set it up. I don't know if you can set yours up like I did, but thought I would help you out. You have to remember, the further back your hitch is, the more leverage you will have on the tractor overall. The closer, you will pull down harder on the axel w/o raising your front end. If you have a fast hitch, I would reccomend you staying with it since you seem to be nose heavy. Best of Luck!!
Chad 1206
01-27-2004 19:41:53
What brand and style are your tires? I run 14.9 Firestone long bars on a Super M and run about 9 to 10 psi for a clay track-no fluid in the tires. Seems to provide the best traction.
The only other suggestion I would have is to redo your hitch, if you haven't done so already. Move the hitch to the max height and under the tractor (towards the front) as far as rules allow. Rules in my area allow 20" high and no closer than 18" from center of axle to hitch. This should pull down more on the back of your tractor, hopefully provide more traction.
Good luck.
Red Boy
01-27-2004 17:55:08
I pull a 560d and I run 15.5-38 unloaded. But I have 5 wheel weights on each side all the time weither im pulling or farming with it. I would unload your tires and use wheel weights so that the weight is being distributed evenly on each side. If you would run loaded sometimes the tires dont always each get the same amount of fluid and then one side will be heiver causing the other to spin out quicker. Hope this helps.
junkyard dog
01-28-2004 17:03:19
 Re: Re: Need more traction for my 460d. in reply to Red Boy, 01-27-2004 17:55:08
I've got a 560d with 16.9 38 fiel&roads makes it a whole different tractor than when it had 15.5s. pulls best 85,9500
