More power out of a JD A
matt
01-27-2004 08:44:10
I have a 48' John Deere A that is completely stock. I want to do a lot of antique pulling this year and I am looking for suggestions with my motor. I am going to get a set of pressed steel wheels and run a 12-38 tire I think, Opinions on this appreicated too. But should I bore the motor to .125 and run aluminum pistons and do head and carb work or should I not do any of that. In a couple of years I am going to go big with the motor, but right now I want to stay some what small with the cubes. Any great ideas???
Green Weenie
01-27-2004 09:59:55
 Re: More power out of a JD A in reply to matt, 01-27-2004 08:44:10
For what you are thinking about I would slug the pistons about 3/4 of an inch put in a 60 or 620 cam get some radius rockers and do a whole bunch of head and manifold work. Just my opinion, if its a creeper gear A weight it up heavy and go for it!
ron john
01-30-2004 08:06:41
 Re: Re: More power out of a JD A in reply to Green Weenie, 01-27-2004 09:59:55
what do you mean when u said u would slug the pistions about 3/4 of and inch, im just curious
buickanddeere
01-28-2004 07:01:24
The 47 and later cam has the identical part number as the 60 cam. The 47 A and maybe earlier, 60,620 and 630 all have the same cam duration and lift. I agree, install the creeper gears and learn balancing the tractor. Plus nothing pleases the crowd more and annoys the other "stock" pullers. Is when a true stocker just slowly putts up the track and into one of the top three positions.
Jack
01-27-2004 12:25:12
Being a 48 it will be 2.5 mph in first gear which is tough on a non stroked A engine.You can use some reduction gears out of a 50-52 A and get the ground speed down enough to keep the engine alive.If you leave the gearing the same and don't stroke it than you definatly need to get it as light as you can cause on a good hookin track at 5500 to 6000lbs you will probably power out.
Weedbender 60
01-27-2004 14:24:40
 Re: Re: Re: More power out of a JD A in reply to Jack, 01-27-2004 12:25:12
Pull with it this year with the stock motor. After ya get your balance, tires and weight brackets and all of that good stuff done then build the motor the way you want it and then next year let her make some noise. Pulling tractors can be a money pit if ya do things twice so try to do all the engine work at the same time. Another advantage of having an underpowered tractor is that you get better at reading ground conditions and balancing your tractor. If you are not in a big hurry and want to get educated this is a good way to get into pulling. HAVE FUN !!!!
farmall
01-27-2004 16:27:53
 Re: Re: Re: Re: More power out of a JD A in reply to Weedbender 60, 01-27-2004 14:24:40
I agree with Weedbender60. Jump in & get your feet wet before breaking the bank. This way you can learn what you need to do, and do it once.
