where can you find pistons for a 44 mh
jd2830
01-26-2004 11:03:40
where to find quality pistons for a mh 44. Thanks in advance
Masseypuller
01-26-2004 17:32:05
 Re: where can you find pistons for a 44 mh in reply to jd2830, 01-26-2004 11:03:40
For a 4.5" bore, I would recommend the V549 international gas truck piston. For any other bore, bigger than 4.0625", I would contact JE Piston, Childs and Albert, or Arias Piston.
If you try to find an OEM piston to work, it is my experience that by the time you have the other machine work done, you will have as much money or more into the pistons. This machine work could be milling piston tops to the correct compression distance, re-bushing rods to a smaller size, or machining clearance into the piston to facilitate rod clearance.
Regards,
Maseypuller
[email protected]
