how big can you bore a 44 mh block
jd2830
01-26-2004 11:01:25
How big can you bore a 44 block before you have to off set bore. Any truthful info appreciated. Thanks in advance
Masseypuller
01-26-2004 17:15:45
 Re: how big can you bore a 44 mh block in reply to jd2830, 01-26-2004 11:01:25
A MH44 block can be bored to 4.5" on-center safely (read as "durably"). 4.625" bore is possible on-center, but the block gets farely thin in the 1 - 2 and 3 - 4 areas.
The V549 international truck piston (4.5" bore) is a very convenient piston that will work with a 5.5" to 6" stroke. I would recommend no greater than 6.75" stroke with this bore, as it may be difficult to clear the rod on the sides of the sleeve or block bore.
A MH44 block (to answer the other posted question) can be bored/sleeved to accept a 5" piston.
blake
01-26-2004 19:26:50
 Re: Re: how big can you bore a 44 mh block in reply to Masseypuller, 01-26-2004 17:15:45
Where could a person find the 4.5 pistons and sleeves for a 44?
JDBert
01-26-2004 15:00:20
jd2830,
Drop this guy a email, he can help you with whatever you need on a massey harris. His name is Gary Herrell.
[email protected]
