sleeves
farmall
01-21-2004 07:19:02
Looking for a catalog or web site that has a size & application listings for sleeves. Would greatly aid in retro fitting old tractors for pullers. Why buy custom, if you can match up something close? Just trying to keep cost of bad habit down.
Any info would be GREATLY appreciated. Thanks in advance
FARMALL!!
01-21-2004 16:07:13
 Re: sleeves in reply to farmall, 01-21-2004 07:19:02
Farmall Here is what I came up with.
you said you needed a 3.5 bore, 4"od, and around 8 long. I found 3 different ones that may be close.
1, Out of a WD45 Diesel, 6 cyl
3.5 bore
3.970 OD .250 flange
3.902 pilot
3.800 Barrel
3.839 seal
7.928 length
#2 Out od AC D-10,12 and H3 crawler gas engine
3.5 bore
3.994 od .247 flange
3.821 pilot
3.805 barrel
3.769 seal
7-1/16 long
#3 out of AC D-15,and HD3 crawler Diesil engine
3-9-16 bore
3.98 od .250 flange
3.912 pilot
3.873 barrel
3.84 seal
8-1/16 long
Hope this helps, That is the only 3 that come close in the Clevite books, Hope this helps. ChadS
farmall
01-22-2004 06:23:40
 Re: Re: sleeves in reply to FARMALL!!, 01-21-2004 16:07:13
Thanks, CHads. I was wondering if you could tell me the name of the catalog and catalog # so I can get one and not bother people like yourself, because I now you have better things to do than find sleeve sizes for me. Thanks again, FARMALL
ChadS
01-22-2004 06:59:17
 Re: Re: Re: sleeves in reply to farmall, 01-22-2004 06:23:40
I hope those may work,, It is a Clevite Sleeve and piston catalog,, it is an older book. I was glad to help if I did,, If you need another spec,, just ask!!! I think I got this book from Burns Industrial supply. ChadS
Flogger
01-21-2004 07:24:31
You might try Darton and LA Sleeves. They have pretty good web sites, and they do have some application charts for some of their regular production sleeves.
ChadS
01-21-2004 08:11:38
 Re: Re: sleeves in reply to Flogger , 01-21-2004 07:24:31
Farmall, I have a book that has all of the sleeve specs you can ask for. If you like, post it on here or send me an email on what you are looking for. The book I have is a Cleveite piston and sleeve parts, and sales catalog. Hope this helps. Chad
farmall
01-21-2004 14:39:39
 Re: Re: Re: sleeves in reply to ChadS, 01-21-2004 08:11:38
Thanks CHADS, that would be great! I am looking for a flanged wet sleeve with o.d. around 4" plus flange & around 8.0" long and bore around 3.5+ and 'o' ring grooves at 6 3/8 & 6 3/4 Thanks in advance! Farmall
Bigred
01-22-2004 18:41:08
 Re: Re: Re: Re: sleeves in reply to farmall, 01-21-2004 14:39:39
Farmall, I have a set of four new sleeve assemblies for a WD45 diesel that are a 1/16 overbore conversion , 3.5625". The o-ring grooves fall in the area you specified also. If interested, e-mail me.
ChadS
01-21-2004 15:15:38
I will look tonight,, should have something by the afternoon. There is about 30 pages of sleeve specs in this book, and 50 pages of piston specs. Later!! Chad
