77 piston
tt
01-18-2004 14:24:16
does anyone have an idea what kind of car piston you can use in a oliver 77 4 inches or smaller with a 1/4 in. stroke? thanks in advance!!!!! !!!
Mike B
01-19-2004 04:17:05
 Re: 77 piston in reply to tt, 01-18-2004 14:24:16
If you want to stay under 4". I would think about useing a set of M&W sleeves and pistons for an 88. Mike
bigmotors
01-18-2004 17:30:59
What seems to work well is Chevy early diesel 4inch piston. Or any small block piston will work, just get out the ruler and calculator.
Good Luck!
ChadS
01-18-2004 14:58:34
If it has a 4 in stroke, you could use a 4 in 99 piston, Should go right in. I could be wrong, Chad
