decking block
champspa
01-17-2004 14:44:34
I have rust pockets on the deck of the block where the head gasket didn't cover . Scrapped them out and they are about .030 deep. can I fill these with an epoxy or shall I have the deck ground it's a 450 farmall and it's a sleeved engine the sleeve lip is just .085 thick . give me some ideas .
ChadS
01-17-2004 17:06:45
 Re: decking block in reply to champspa, 01-17-2004 14:44:34
Install the sleeves, have it decked .015, and use JB weld in the deeper spots to fill in the dips, Should have a nice flat surface. Just my 2 cents worth, JB weld will hold as long as it is not in direct contact with the compression fire heat. Hope this helps,,
champspa
01-17-2004 17:21:28
 Re: Re: decking block in reply to ChadS, 01-17-2004 17:06:45
thanks ChadS for the info. have you got a .020 headgasket ? email me the price
Chads
01-18-2004 08:13:16
 Re: Re: Re: decking block in reply to champspa, 01-17-2004 17:21:28
Sent you an email!! Chad
champspa
01-18-2004 14:04:08
 Re: Re: Re: Re: decking block in reply to Chads, 01-18-2004 08:13:16
got it I'll let you know on the gasket. thanks again
