Tim C., thanks for the plans!!
Curious?
01-17-2004 09:56:10
Hey Tim, thanks for sending me that info, I saved it to disc, going to print it out. I read through all the info, were going to build one, no doubt about it, doen't look to bad at all! It will be nice to have a personal flowbench, make porting a lot more accurate affair. thanks again Tim!! someday hopefully I can return the favor!
Sandyland Puller
01-17-2004 17:47:18
 Re: Tim C., thanks for the plans!! in reply to Curious?, 01-17-2004 09:56:10
I am also interested in building a flow bench. could someone please send me a copy of the plans.
Thank You.
TimC
01-19-2004 06:46:53
 Re: Re: Tim C., thanks for the plans!! in reply to Sandyland Puller, 01-17-2004 17:47:18
I haven't got a return notice yet so I guess you got it.
Sandyland puller
01-19-2004 18:56:21
 Re: Re: Re: Tim C., thanks for the plans!! in reply to TimC, 01-19-2004 06:46:53
Thanks for the plans.
Hey Tim C!
01-17-2004 11:01:59
Listen, if Tim C sent you plans for some idea of his, THROW THEM AWAY!! I got to see the Under Pressure 88 he supposedly works on of the Head Boys, it runs like crap!! They need to take it back to Duke!! It should be called UNDER POWERED!! It has no power, the governor appears to be out of wack, it idles rough,etc. TIMC needs to actually pull something of his own to show everyone what he can do! He reads HOT ROD magazine, then all of a sudden is a super tuner for 600 c.i. 88's? WRONG!! Maybe that's why he wasn't there so he wouldn't look stupid when it ran like crap!!
ChadS
01-17-2004 20:25:19
 Re: Re: Tim C., thanks for the plans!! in reply to Hey Tim C!, 01-17-2004 11:01:59
I noticed a phrase in your post,, you seen it pull, so I take it you did not pull or pull against it, right? Tim and the crew have the bragging rights to at least be able to hook to the sled. So what if it was not right in you opinion. It may be right to them. Usually when you but a puller from someone, you are either buying a tractor that was someone elses head ache, or just was not right to start. At least they can hook up and try. It is a learning experience. What did you pull there sir? Let me see your name in the money, and if it is not, we won't laugh at you.. Just take your money. Just my pennys worth.
hey CHADS
01-18-2004 10:22:27
 Re: Re: Re: Tim C., thanks for the plans!! in reply to ChadS, 01-17-2004 20:25:19
you are just like Tim, a lot of talk about pulling, but no action! So why can't us other "nonpullers" (just like you and Tim) also brag about what we can (or can't) do? You guys drive us nuts! The 460-H thing is a joke! Maybe he can flow the head for you!!
Chads
01-18-2004 12:56:37
 Re: Re: Re: Re: Tim C., thanks for the plans!! in reply to hey CHADS, 01-18-2004 10:22:27
HA HA HA HA!!!!! Little less talk and a lot more action huh? I can talk pulling because I can, and know how to do it, and not sit along the side line and judge and call the others stupid. If you can do better, go volonteer your service!! I am sure they would pay you generously to figure out, (if you can) Seems like all you are bragging about is holding up a fence that you stand next to!! Why would the 460 H be a joke? Nothing special about it, I said that, Why don't you pick on a tractor that wins, or places in the top 3 every time it hooks!!! Pick on my H, Now, there is a little less talk, and alot more action!! Ask anyone who has seen it pull!! So lets hear you formula for the perfect tune up.. You said you can tune it better, so go on!! Tell Tim how to tune Under pressure!! Oh wait, you said take it to Duke. Is that the best you can do?
Curious?
01-17-2004 13:06:02
Hey, he sent me plans for a flowbench, yes they are out of hot rod, but why don't you wiggle your way over to the pulloff or fondas board and see what the NTPA boys say about those plans, they have built the same one, they say it works just as good as a superflow factory bench. So tell me, if you're the authority on motors, what do you pull?? Do ALL the engine yourself?? Just curious, if someone's going to start throwing stones, better be ready for the rebounding ones.
Donald T.
01-17-2004 13:57:17
 Re: Re: Re: Tim C., thanks for the plans!! in reply to Curious?, 01-17-2004 13:06:02
I'm just telling what is fact! Timmy is the "self proclaimed" expert-tuner! Didn't he boast about how strong "Under Powered" 88 was? I think I could make it run that well!!
TimC
01-19-2004 07:29:21
 Re: Re: Re: Re: Tim C., thanks for the plans!! in reply to Donald T., 01-17-2004 13:57:17
Hey little buddy, been missing you. Hope you get all this out of your system before its to late. Its a fearful thing to enter into eternity with a something like this in your heart.
