WD-45 for pulling
Dan
01-16-2004 17:32:43
I just bought a 54 wd-45 and would like to pull it. There are a lot of farmall m and super m's in my area and was wondering if i could do any good or what i could do to my tracor to be competetive. Thanks alot. Dan
Bluewrench
02-02-2004 18:06:47
 Re: WD-45 for pulling in reply to Dan, 01-16-2004 17:32:43
Power costs man. Anything is possible with an Allis, But it all depends on the size of your wallet.
Don
01-20-2004 08:33:53
I agree wit the other posts. Depending on what you wanted to do with you WD-45. If you do get inetested in increasing the size of your motor, I have parts that will get you going.
KBMO
01-19-2004 10:27:51
A WD-45 will pull very competitive stock at #4000 and #4500. As long as you are pulling against other "stock" tractors. The WD-45 has a lower first gear than a WD or WC so that will help you if you want to pull heavier and still run the stock motor. Depending on your rules you would be much better off on most tracks to run 38 in. tires instead of the 28 in. that came on it. If you want to do some motor modifications the WD-45 if fine up to about 330 cu. in. If you go bigger than that you better get a Gleaner E or D-17 block. A 4 1/8" overhaul kit will get you to 51 HP on the stock motor.
Dave
01-17-2004 19:41:12
The red (and the ollies also) tractors are using 38" rubber on the rears while you have 26" or 28"... which means they have many more square inches of tire on the ground. You can get some rear end parts from a allis r or rc (something like that) to get your ground speed slower so you too can run the 38" rubber.
With the engine you have now you will need to bore and stroke it or you need to get a gleaner model E combine motor (same as a D-17.. same block as what you have now). This motor will be mid to upper 40's for HP. It will all depend upon how deep your pockets are and what classes you are going to pull. There are alot of helpfull people on this board who can help you. Good luck and have fun.
Chuckster
01-17-2004 05:50:56
Well congradulations on you purchase.Alot depends on how much money you want to spend or what classes/div.you want to pull.Please be a little more specific on what you plan to do.AS in farm stock/div2,3 on up.
