OK stupid question
marlowe
01-15-2004 16:01:56
what is a dead weight pull ??? i have pulled for years and all we use is a transfer sled
buickanddeere
01-16-2004 20:33:24
 Re: OK stupid question in reply to marlowe, 01-15-2004 16:01:56
The ancestor of transfer weight sleds. Some dead sled competitions tossed weight at intervales or had volunteers step on.
Joe
01-16-2004 07:59:53
This is my take on deadweight pulling i've been doing it for 16 years now along with transfersled. If you want to learn how to how to really set up your tractor for what ever changes you make to it goto the deadweight pulls tire pressure and weight placement is critical always want to start out with as low of throttle as possible to get the tractor underload to start and don't hammer it once you are moving 9 out 10 will spin out any other question email me .a 2cyl usally rules at this later joe
marlowe
01-15-2004 19:34:01
thanks i'll stay with the transfer sled we get to go 300ft. at least thanks
Red Boy
01-15-2004 17:25:15
It starts out as stoneboat or a cement sled that has a set weight for each class and after the first round ends in that class then more is added untill there is only the winner left. Most of the weights a cement that weigh about 1500lbs. I think the distance is somewhere around 20 to 22 feet. And unlike transfer the holes and dirt do not get filled in or swept away it all stays till the class is over. Then the sled is moved and the old track is leveled off. And it goes like this for every class.
IH H Puller
01-15-2004 16:59:34
From what I understand, it is a lot like draft horse pulling. The sled is a set weight and whoever can pull it so far goes to the next "round". They add more weight to the sled and go again until there is a winner. this is just what I heard, I believe the distance they have to pull is 22.5 ft. I hope you get some more info from someone that know a little more.
junkyard dog
01-15-2004 17:43:52
 Re: Re: OK stupid question in reply to IH H Puller, 01-15-2004 16:59:34
we do alot of deadwt. pulling here in eastern ny ,western new england. distances pulled vary alot,anywhere from 6'[boring] to100' and anywhere in between.deadwt pulling is not a power game,is actually a place where "stock" tractors can beat the hot rods.
Joe
01-16-2004 07:29:52
 Re: Re: Re: OK stupid question in reply to junkyard dog , 01-15-2004 17:43:52
Where in eastren ny do you pull matbe we have pulled together some time.
Dave
01-15-2004 19:18:29
It sound like it would be hard on the clutch to get all that dead weight started, at least with a transfer sled it is easier to get it started. some of the smaller tractors have a problem getting them started.
ChadS
01-15-2004 19:28:56
 Re: Re: Re: Re: OK stupid question in reply to Dave, 01-15-2004 19:18:29
It is actually the opposite, the bad thing about deadweight pulling is when the front end comes down hard on the pavement when you don't move the sled. Usually the smaller tractors out pull the big tracors, and the stock tractors always out do the hot rods. dead weight pulling is the only type of pulling where HP will bite you in the A$$!! It is a class of balance, tire pressure, and braking just right,, 85% of the pull the front end is off of the ground, so you have to spin it with the brakes to turn to go where you want it,, To describe a deaweight pull,, "Graceful" if it does not move, you either spin, or stall the engine. just my 2 cents. Chad
junkyard dog
01-16-2004 12:10:59
 Re: Re: Re: Re: Re: OK stupid question in reply to ChadS, 01-15-2004 19:28:56
most of our pulls are in dutchess and columbia counties in ny. sometimes venture further north or across the hudson if nothing going on locally.right now the itch is getting pretty bad,havent pulled since oct. going to go out to akron oh. in march cant wait. where you from joe?
ChadS
01-16-2004 17:52:29
 Re: Re: Re: Re: Re: Re: OK stupid question in reply to junkyard dog, 01-16-2004 12:10:59
I am located in north central Indiana
Joe
01-16-2004 14:05:19
Hey Junkyard i pull in washington,saratoga,madison,fulton counties schaticoke and mcfaddens fathersday pull have been down to walton and morris in the past. i live in schuylerville and also pull with the tri state antique club we have our meeting this sunday.have also ventured out to granby mass,and addison vt want to try boonville and lowville and malone this year. I pull a cockshutt 40 deluxe 90%of the time.
