Booneville, MS Pull (January 31, 2004)
Spotter
01-14-2004 13:19:18
Booneville, MS..January 31, 2004..Dixie Iron Tractor Club...Start time: 11::00AM...Agri-Center (indoor).
Farmstock....3000-10,000# (low gear)
Superstock...3500-10,000# (low gear...hang on weights allowed...no cut tires)
Modified..... 4500-10,000# (1st & 2nd gear only...cut tires and hang on weights allowed)
Spotter
Hillybilly Hookee
01-14-2004 20:39:46
 Re: Booneville, MS Pull (January 31, 2004) in reply to Spotter, 01-14-2004 13:19:18
WHASSUPP Spotter? cant make the Boneville but will be in Cleveland. Yall got any of that clear antifreeze in case its real cold that weekend? See yall there H.H. p.s. tell Fat Lady to take it easy on me this year, that was plum embarrassing last year.
Spotter
01-14-2004 22:05:12
 Re: Re: Booneville, MS Pull (January 31, 2004) in reply to Hillybilly Hookee, 01-14-2004 20:39:46
H.H....Always plenty of anti-freeze whether the weather be cold or hot (all season formula). Well, the Fat Lady will be sporting a new pair of shoes this year with a special "cut" to compensate for all them Arkansas rocks. All we got to do is lace 'em up....Spotter
john - cleveland rules pl
01-14-2004 17:38:53
Will the rules for Cleveland be the same? What we would bring would be stock with hang on weights. Might round up enough stock weights for a 'stock' class if need be. Do we have to take off all our weight brackets for hangons and studs for wheel weights if we pull stock? Thanks for the info.
John
Spotter
01-14-2004 18:59:48
 Re: Re: Booneville, MS Pull (January 31, 2004) in reply to john - cleveland rules pl, 01-14-2004 17:38:53
John,
Rules for Cleveland will be different. Mean Green pulls what we refer to as Farm Stock II which allows hang on weights, 10% over stock RPM, 1st gear only, 4MPH max. I have the rules on the Mean Green site. www.greenpullers.com....Spotter
John again
01-14-2004 21:08:29
 Re: Re: Re: Booneville, MS Pull (January 31, 2004) in reply to Spotter, 01-14-2004 18:59:48
Are wheelie bars "really" mandatory for farm stock tractors? Not sure if I can find time to make a set.
John
Spotter
01-14-2004 21:57:22
 Re: Re: Re: Re: Booneville, MS Pull (January 31, 2 in reply to John again, 01-14-2004 21:08:29
John,
The Booneville pull has a Farm Stock (Div.I) where they most likely are not mandatory.
They are mandatory at the Cleveland pull as it will have only Div.II Farm Stock Class.
Spotter
Rules?
01-14-2004 13:51:57
What is your RPM limits if any? and Ground speed limits if any? Do you have your rules posted anywhere on the internet where they can viewed? Thank You
Spotter
01-14-2004 15:00:45
 Re: Re: Booneville, MS Pull (January 31, 2004) in reply to Rules?, 01-14-2004 13:51:57
20% over stock RPM...No speed check..Just pull gears as stated. 18" drawbar max height in Farm and Super Stock. 20" max in Modified. They have no site that I know of. No money, just trophies. Just some good old boys having a good time..
Spotter
Two-Tone
01-14-2004 16:00:07
 Re: Re: Re: Booneville, MS Pull (January 31, 2004) in reply to Spotter, 01-14-2004 15:00:45
Do you allow 901 FORDS from Arkansas? Will plan to be there if I don't have to work or need long jons.
tt
Spotter
01-14-2004 16:57:32
 Re: Re: Re: Re: Booneville, MS Pull (January 31, 2 in reply to Two-Tone, 01-14-2004 16:00:07
TT...Yep to the Fords and it is inside with some good heaters...Spotter
Hey GPower-JDGnut
01-14-2004 16:38:32
Hey GPower....
Are we up for a haul like this?? Booneville and Cleveland???? JDGnut
Spotter
01-14-2004 17:03:16
 Re: Re: Re: Re: Re: Booneville, MS Pull (January 3 in reply to Hey GPower-JDGnut, 01-14-2004 16:38:32
Nut...Cleveland will be the following week-end. Ya'll can do it. Will be a good start for the new year. Booneville will be "loose" as usual and Cleveland will be "tighter" and pays $$$. When will the "Rock Crunchers" start up? Spotter
JDGnut
01-15-2004 06:12:15
 Re: Re: Re: Re: Re: Re: Booneville, MS Pull (Janua in reply to Spotter, 01-14-2004 17:03:16
If we come.. We're coming for the "Fat Lady"!!!... Ha Ha.... JDGnut
Spotter
01-15-2004 08:58:02
 Re: Re: Re: Re: Re: Re: Re: Booneville, MS Pull (J in reply to JDGnut, 01-15-2004 06:12:15
NUT...The Lady ain't easy but she can be had!!! LOL..Spotter
piston
01-15-2004 05:12:52
listed as a 1st. pull mammoth springs ar. march20th, 04.
