Mating Smaller Width Rods to Larger Width Crank Jo
Large Al
01-13-2004 19:42:17
Anyone know if you can get a rod to fit with a crank journal that is wider than the rod is? If you can, how? Thanks in advance for any help!
Jerry B
01-14-2004 07:28:16
 Re: Mating Smaller Width Rods to Larger Width Cran in reply to Large Al, 01-13-2004 19:42:17
The safest way is to shim the piston at the wrist pin boss in the piston. The piston will hold the rod centered on the journal.
Large Al
01-14-2004 19:09:02
 Re: Re: Mating Smaller Width Rods to Larger Width in reply to Jerry B, 01-14-2004 07:28:16
Thanks. So, you're saying to let the piston hold the rod straight and do nothing to the bottom end (crank end). Never thought of it. So this is the safest way?
Jerry B
01-15-2004 07:46:44
 Re: Re: Re: Mating Smaller Width Rods to Larger Wi in reply to Large Al, 01-14-2004 19:09:02
Not trying to "set you up". I have a friend who is helping me with my engine by doing the machine work. He told me he has shimmed many a wrist pin to center a rod.
But usual disclaimers apply. Don't do it if you don't trust it. Besides...Just how much lateral movment do you expect a piston to have?
farmall
01-15-2004 06:08:20
Think about it! The piston is a loose fit in the bore, with cam ground pistons, the can rock in the bore! The rod bearing would'nt like that.
I think this last posting is trying to set you up!
Don't cut corners. This would be like not running any thrust brg's. on crank! Would that work?
Rod
01-13-2004 19:51:33
I have welded small stringer beads on the side of the rod and machined them flat, or I have seen washers welded on the sides to take up the space, eather works well, just don't get the rod verry hot and make sure it will not rub the crankshaft radius
