m clutch
TL
01-11-2004 18:45:38
What type of clutch would you recommend for a div2 farmall m?Would a stock set hold up?Thankyou for your advice
Farmall Daddy
01-12-2004 15:55:47
 Re: m clutch in reply to TL, 01-11-2004 18:45:38
Me and my dad run a stock M clutch in ours when we pull. Ours kicks 65 horse and it hasn't ever slipped once. Best of luck!
Proredpuller
01-12-2004 08:14:45
I used a new stock disk but rebuilt the pressure plate for more holding pressure (not much) by shimming the springs. Worked fine in Div II and III with no slippage using 18.4/38 cut tires. I don't have my old spring data but just used standard practices for valve springs.... measured with a valve spring machine, then shimmed to increase as necessary... but don't go too much and bind it all up. That's my experience and hope it helps.
Jim
01-12-2004 07:52:05
E-mail me. I have new clutch parts at half price I will not be using. [email protected]
WILDMAN
01-12-2004 07:48:36
CAN'T GO WRONG WITH ABUTTON CLUTH.
ChadS
01-12-2004 13:37:40
 Re: Re: m clutch in reply to WILDMAN , 01-12-2004 07:48:36
Wildman,, did you get your new block yet?
WILDMAN
01-13-2004 05:33:58
 Re: Re: Re: m clutch in reply to ChadS, 01-12-2004 13:37:40
ITS DONE BUT I HAVE NOT PICKED IT UP. I HAVE TO ORDER PISTONS,NOT SURE AS TO DROP PIN HIEGHT A LITTLE TO REDUCE COMPRESSON.ITS AT 295PER CLLINDER WITH 4""60 OVER STOPPED 1/8 FROM TOP OF BLOCK NOW .WHAT DO YOU THINK?
ChadS
01-13-2004 07:56:41
 Re: Re: Re: Re: m clutch in reply to WILDMAN, 01-13-2004 05:33:58
You should be ok,, you can go up to 310psi and still be ok.. just make sure that the deck of the block has been resurfaced, otherwise the head gasket may not seal with that kind of compression. If you have room to offset the pin, you can do it that way,, or if you are going to run chevy pistons,, just gety a low compression piston, one with a dish instead of a dome,, Chad
