Allis D-19 Gas Thin Cam and Stroking
LargeAL
01-11-2004 17:07:08
I wanted to get a little more power from my D-19 gas motor so I stroked it 1/2". I was clearance grinding in the engine and ran into a problem. The crank and rod hit the cam pretty solid. Does anyone know how much I will have to notch the cam for the rod to clear? It still has the stock standard rods in it. I am afraid that I will break the cam if I go too thin! Help! Has anyone out there did this to a Buda?
TimC
01-12-2004 06:15:28
 Re: Allis D-19 Gas Thin Cam and Stroking in reply to LargeAL, 01-11-2004 17:07:08
Can you replace the stock rod cap bolts with cap screws and gain some clearance?
Large Al
01-12-2004 06:58:40
 Re: Re: Allis D-19 Gas Thin Cam and Stroking in reply to TimC, 01-12-2004 06:15:28
Yes, that would help a lot. What type of bolts are good to replace them with? Thanks.
Little Al
01-11-2004 19:48:38
AC didn't leave much room in there block for stroking. Stock rods won't work. Start with super c IHC rods and you can stroke 1 inch without alot of grinding. Cams have been ground to .485 and worked but not for to long. Sorry but these blocks started at 230 cu in when they were built and 262 were as big as AC ever made them.
Large Al
01-12-2004 07:02:41
 Re: Re: Allis D-19 Gas Thin Cam and Stroking in reply to Little Al , 01-11-2004 19:48:38
I planned to do a flat cut on the cam. Would that help with holding it together? Thanks for that information. I may have to redo the crank. Any modifications have to be made to the Super C rods?
Jason
01-12-2004 07:10:06
 Re: Re: Re: Allis D-19 Gas Thin Cam and Stroking in reply to Large Al, 01-12-2004 07:02:41
If you stroke to 1 inch more and use super c rods can you use the factory pistons? Or is there a bigger piston that will work with this combo?
