1256 vs. 856
CPoosch
01-09-2004 05:31:11
Can I get a 1256 down to 8000lbs relatively easy, or should I be lighter to begin with and turbo an 856?
CP
856 puller
01-12-2004 17:24:56
 Re: 1256 vs. 856 in reply to CPoosch, 01-09-2004 05:31:11
we run a 856 at 8500 with 300lbs. moveable we have a fiberglass front and fenders but i have seen guys make the weight without them.
856 puller
01-12-2004 16:58:12
E J
01-09-2004 13:14:32
The 706 rear end is the lightest of the 06&56 tractors the axle housing& bullgears are lighter rest the same.
L Hud
01-09-2004 06:20:31
1256 and 856 is basically the same tractor.
brandon
01-09-2004 07:27:33
 Re: Re: 1256 vs. 856 in reply to L Hud, 01-09-2004 06:20:31
I was told that the 1256 is the same as a 856 exept that the 1256 has a turbo on it. I have pulled a 856 before but could only get in to 10,000 class and at that it was very close.
Charles Poosch
01-09-2004 09:38:10
 Re: Re: Re: 1256 vs. 856 in reply to brandon, 01-09-2004 07:27:33
I guess what I'm getting at is if the reared and transmissions are different (lighter) than each other or if it was the same basic unit with a turbo tacked on.
I should have mentioned that this will be a stripped down puller. Pressed steel wheels, all the pto, 3 point stuff gone, new front axle, aluminum fenders, small fuel tank, smaller batteries, etc.
CP
ChadS
01-09-2004 10:51:40
 Re: Re: Re: Re: 1256 vs. 856 in reply to Charles Poosch, 01-09-2004 09:38:10
Could a 706-806 rear end be any lighter?
Charles Poosch
01-10-2004 07:56:30
 Re: Re: Re: Re: Re: 1256 vs. 856 in reply to ChadS, 01-09-2004 10:51:40
Yeah, a 706 would be ideal, but the rearend has to match the model designation according to the rules...
CP
