MM GBD bore size/fuel pump
Mopower
01-08-2004 11:12:31
Hello again. I have a nice old GBD that could use a boost. The compression is weak so it takes a minute to warm up and run smooth. If I switched to bigger 4-5/8" blocks (like G1000) when I rebuilt it, would the stock fuel pump and injectors be sufficient to run the slightly larger motor (504 vs. 426) to it's potential? Thanks for any info you have.
Ethan Berry
p.s. I have a UBD with 5-star pump and injectors and G900 blocks (about 300 cubes vs. old 283). Starts a little funny and runs decent, but timing and injectors may be off. I bought it that way, but have not worked on it yet.
Jerry
01-12-2004 07:39:54
 Re: MM GBD bore size/fuel pump in reply to Mopower, 01-08-2004 11:12:31
Wasn't the G stock at 4 5/8?
Mopower
01-12-2004 16:53:51
 Re: Re: MM GBD bore size/fuel pump in reply to Jerry, 01-12-2004 07:39:54
Not the GBDiesel. 4.25x5 six cylinder diesel engine. Gasers were 4.625x6 four cylinder.
E J
01-08-2004 14:11:06
How much trouble would it be to change over to a roosa master pump and lines with that it should make a 100hp.Ihave a Massey 97 with 100hp+
Mopower
01-08-2004 15:05:49
 Re: Re: MM GBD bore size/fuel pump in reply to E J, 01-08-2004 14:11:06
I could go pretty far with a GBD, but would like to keep it fairly original looking. I know some have been converted and I see some healthy GVI machines. Just not so knowledgeable on diesel stuff. Massey eh? Sweet!
Joe
01-09-2004 16:23:01
 Re: Re: Re: MM GBD bore size/fuel pump in reply to Mopower, 01-08-2004 15:05:49
Ethan,
If you ever decide to sell the GBD let me know. I would really like to add one to my collection of stuff.
Thanks
Joe
Mopower
01-09-2004 21:59:33
 Re: Re: Re: Re: MM GBD bore size/fuel pump in reply to Joe, 01-09-2004 16:23:01
Everyone wants that thing. Including my Dad. Hard to find one that is decent shape and runs good. My last big addition to my collection. I'll try to get a picture out there of it.
