New Project - Farmall H Div III Puller - Need Advi
Proredpuller
01-08-2004 06:31:48
I'm starting a new project, moving from an M to an H. Anyone out there that might have some success stories relating to a Farmall H Div III puller would be much appreciated. Really wanting to get an idea of stroke/bore and parts combinations that have been proven to work so I don't have to learn all the lessons over again. Might be willing to purchase a complete engine if someone has one available. Any help that can be provided will be much appreciated.
Thanks in advance.
GARY BAKER
01-08-2004 13:47:54
 Re: New Project - Farmall H Div III Puller - Need in reply to Proredpuller, 01-08-2004 06:31:48
I have built several 'H' motors. A very popular one is to use a 300-350 block. Pull out sleeves and bore is 3.750. SBC pistons for 305 + .020 are 3.756. Or you can go bigger if you like.
Strokes i have used range from 5.375 to 5.750 with stock rod. Rod needs to be narrowed and machined on big end & ctr. sunk allen bolts in place of stock. Cam will need flats machined on them to clear rod. The H's if dynoed range from 80 to 110 HP & 540 RPM'S. At 110 HP the pto does'nt like to dissengage any more, so unless you don't care about your pto, don't dyno above 100 hp. Hope this helps.
Sleddog
01-08-2004 15:32:42
 Re: Re: New Project - Farmall H Div III Puller - N in reply to GARY BAKER, 01-08-2004 13:47:54
I am also gathering parts to build a Farmall H. I have a 350 International block. Where can I get a crank and pistons to go with it at the 3.75 bore and 5.75 stroke. Additional information and a method to contact personally will be appreciated.
Proredpuller
01-08-2004 14:46:56
Gary,
Thanks so much for your input. Your name came to me highly recommended for H pulling motor info so I'm glad to hear from you before I had to try and find you. I would like to talk more with you as this project develops. Thanks again for all your help. I sincerely appreciate it.
GARY BAKER
01-12-2004 12:22:28
 Re: Re: Re: New Project - Farmall H Div III Puller in reply to Proredpuller, 01-08-2004 14:46:56
If you would like more info, and where to buy necessary parts I would be glad to help. daytime 734-428-09688 or cell 734-678-9688
FB
01-09-2004 09:53:28
You owned that black M with polished aluminum rims didn't yah?
proredpuller
01-09-2004 12:18:38
 Re: Re: Re: Re: New Project - Farmall H Div III Pu in reply to FB, 01-09-2004 09:53:28
yes sir, I did have a Black M for years that found its way to Mississippi last year. It was for sale in the Hook for a couple months around this time last year. In the mean time, I've built a couple tractors for others but that prevented me from pulling last summer so I'm not back into it full force trying to get this H ready.
wilmann
01-09-2004 10:45:57
i have ablack h and m with polished rims. imay have a4"60 over block that i might sell
proredpuller
01-09-2004 12:20:02
 Re: Re: Re: Re: Re: New Project - Farmall H Div II in reply to wilmann, 01-09-2004 10:45:57
H or M block?
wildman
01-11-2004 12:47:29
 Re: Re: Re: Re: Re: Re: New Project - Farmall H Di in reply to proredpuller, 01-09-2004 12:20:02
a h block,with pistons.
FB
01-09-2004 09:53:06
You owned that black M with polished aluminum fims didn't yah?
ChadS
01-08-2004 07:45:06
I have had some very good luck over the years with Farmall H pullers. Been building them for years. My recommondation is to call Gary Baker from MI,, or Lemmons. Both are very good builders. I built my own engines, and have a great idea of what parts to use for them. My recomodation for a good strong div 3,, is a 270ci, 3.852 X 5-3/4 stroke. Makes great power. And this block uses STOCK rods. And all IH parts to build it. Send me an email if you like, I would be happy to try and help you,, You don't have to buy anything to find out any info!! ChadS
