hey Chads
Hack
01-07-2004 21:20:14
Do you know if there is anyone building limited slip for a JD A. THANKS
KY Puller
01-08-2004 19:02:00
 Re: hey Chads in reply to Hack, 01-07-2004 21:20:14
You need one for your A so they can protest you and stay off of everyone else!!
ChadS
01-08-2004 09:18:02
Nothing for the JD yet. We are looking at the differntail housing for the JD,, Do you know if the spiders are tapered between the housing and the back of the carrier housing? If it is flat,, I can come up with something that will work. ChadS
Don
01-09-2004 05:16:47
 Re: Re: hey Chads in reply to ChadS, 01-08-2004 09:18:02
Have you ever done one for a allis?
tractorboy
01-09-2004 19:30:53
 Re: Re: Re: hey Chads in reply to Don, 01-09-2004 05:16:47
I know of something that will work on a car or truck. Double the thrust washers behind axle gears and a car will still have a differential when not under power and lock up under power.
