Broken transmission gear!!!!!
ChadS
01-07-2004 19:51:25
I tore the 460H tranny/rear end plate cover off,, found a broken tooth on 1st/reverse slider gear. Looks like I will tear the whole rear end apart. Going to install a posi/limited slip too. I might post photos of the instalation process of the limited slip/posi kits if you guys like.. FUN FUN FUN!!! ChadS
Wild Horses
01-08-2004 10:13:25
 Re: Broken transmission gear!!!!! in reply to ChadS, 01-07-2004 19:51:25
That'd be great. I've thought about putting a limited slim in my M. Even Cad designed plugs to lock the bull gears together, but didn't like the idea of a permanently locked rear. Are your units cable? Would it be possible to modify it for an electric solenoid?
I've seen a W30 and I would guess he was using a locker. He'd start to lose traction and reach down under the seat. Then suddenly the wheels would sync and it'd start to pull away again.
ChadS
01-08-2004 14:57:43
 Re: Re: Broken transmission gear!!!!! in reply to Wild Horses, 01-08-2004 10:13:25
Nothing electric on this kit. It is designed to slip when you need to hit the brakes to correct on the track and then re enguage afteryou let up on the brake. Or, when you turn sharply, it will allow you to turn without scooting the front tires. the clutch is adjustable, from a limited slip, or make it a full posi just by tightening up the clutch adjustment.. We have kits for div 2-5,, any hp range. It is easy to install,, but, you must disassemble the rear end to remove the differential, and brake pinion shafts, and the brake hubs, is what you would need to ship to me for machine work. ChadS
Don
01-08-2004 05:15:53
Have you ever built a limited slip/posi for a WC?? Looking to do something different but wnat to keep the advantage. If so what price range are we talking??
Thanks
Don
