Division 3 question
Jon
01-07-2004 06:08:08
Can you replace the factory cast iron front axle/wishbone assembly on a standard tractor with a fabricated tubular steel unit and still be legal?? I know I've seen a few W-9's and GBD's done this way but dont know if they were legal.
mike
01-07-2004 17:03:26
 Re: Division 3 question in reply to Jon, 01-07-2004 06:08:08
checking
KBMO
01-07-2004 10:01:43
This would be legal at any div III pull I have been too. NATPA, MATPA or otherwise.
Red
01-07-2004 07:52:49
I pull a farmall H in Division 3 and have replaced the front bolster. I cut the gear box off the top and mounted it on a pipe. Used the gear box and shaft to go down like it was originally but lost the bolster and wishbone. Made a box to go between the rails and beefed it up a little with gussets of 3/8 by 4 inch flat bar. I have never had any problems here and have not found anything in the Natpa rules saying that you cant replace the front bolster. I have put up to 750 pounds in the front and it is holding. We lost a tremendous amount of weight by getting rid of the stock front bolster, might also need to lose some in the back to counter balance it.
farmall
01-07-2004 06:22:19
In div 3 the front bolster should be a stock piece. The tractors you are refering to are in div. 5. Go to NATPA.com and read rules on division you are pulling. Hope this helps
