After I posted I went back and re-read Buzzman's post. I've had this discussion many times with a good pulling friend and neither one has convinced the other that they are wrong in their argument yet! So here it goes..... . If at the end of the pull, the front end is just "lightly" touching the ground, that to me is a perfectly weighted tractor, and it kept your hitch from going down. In this example lets say that you have 700# of weight that you can move on your tractor, front end, middle, back, where ever you want to put it. If 200# will keep the front end down on the ground at the end of the pull, then you have 500# for the rear end to help you from spinning out your tires. Putting 500# in front and 200# on the rear will be wasting 300#. (the front end can only be held so close to the ground) Yes, I've heard of the physics theory of weight is multiplied once for every 1' from the pivot point (200#, 8' from the rear axle =1600#, and I'm sure that it is accurate. But, I know that on my antique puller, I've never had the front tires spin out and stop my pull! You need to keep as much weight on the rear end as possible and still keep the front end down. That is why you need as much movable weight as possible for the different track conditions. It is a good idea to keep a journal describing the pull, track conditions, where you had the weights placed on tractor and the results of pull. When you are winning or losing by an inch, 100# placed in the correct position will make the differance between winning and losing. Good luck!!
