Large carb, who can help me??
curious
01-06-2004 20:03:21
Wonder if anyone knows a good carb shop that can help me out. I have a large aluminum carb, only numbers and name is stamped inside bowl area, built by Alcoa, casting # 12r500fp, the intake is 3 inches diameter, it is a two barrel updraft, each throat is 1.5 inches diameter, would like to use this carb, need someone who knows what it is first, thanks for any help!
Cody
01-07-2004 18:55:57
 Re: Large carb, who can help me?? in reply to curious, 01-06-2004 20:03:21
It is probably a carb like was used on th Heisler 2bbl. set ups. Is it a progessive 2bbl, or do both butterflies open at the same time, or does each butterfly open independently(sp)?
Curious
01-07-2004 21:12:06
 Re: Re: Large carb, who can help me?? in reply to Cody, 01-07-2004 18:55:57
It is not progressive, both butterflies are on the same shaft, open together, Idle adjustment for each barrel, I got the carb at an auction, Fella I bid against said it was military, off a 6x6 if I remember correct, this is the size carb I need for my tractor, and rather than go buy another carb, why not try to make what you already have work first? Right? The only name on the carb is inside, Alcoa, I checked their website, and no info found.
Slo
01-07-2004 18:46:44
Try Matt @ Motec, 765-963-6628
Brad
01-07-2004 14:15:56
Might be an aircraft carb. Possibly off a lycoming engine. I work with lots of single barrel carbs, but not too many 2 barrels.
good luck,
Brad
412-585-3913
PISTON
01-07-2004 05:55:59
I PRETTY SURE THAT CARB,CAME OFF OF MY CLUB FARMALL CAN YOU GIVE THE ## OFF IT ?
Wild Horses
01-07-2004 10:20:58
 Re: Re: Large carb, who can help me?? in reply to PISTON, 01-07-2004 05:55:59
Does anybody else realize that this guy is to smart for the rest of us? May be we should bow down or something.
Come on give the guy a break, Pis(sy)ton.
PISTON
01-07-2004 18:11:40
 Re: Re: Re: Large carb, who can help me?? in reply to Wild Horses, 01-07-2004 10:20:58
o.k. O.K.
