cam specs
greg
01-05-2004 19:53:44
does anyone know the cam specs for a 49 jd a (lift duration ect...) and specs for a jd 60?
lynn
01-06-2004 16:10:29
 Re: cam specs in reply to greg, 01-05-2004 19:53:44
greg..the a and 60 share the same cam..these specs are from a cam i had degreed several years ago..this was an used cam so it had some wear in it..
intake duration at .050 182 degrees
lift .280 inch
exhaust duration at .050 203 degrees
lift .295 inch
lobe center 113 degrees
i measured a 40 model a intake in the tractor..
open 22 ATDC at .050
close 27 ABDC at .050
center 116 ATDC
lynn
