More rollcage questions
john needs a ca
01-04-2004 16:11:21
Anyone know of a site out there with specs for rollcages for modified tractors? I plan to build my own. I see some advertised as 2" .120 wall DOM with 3 tubes in the main hoop. I will not pull above 6,000lbs. I know those cages are designed for hot farm tractors that will weigh several thousand pounds more. Is 2 hoops of 2" enough or 3 hoops of 1.5" or 1.75"? I guess it depends on how fast it is going when it turns over and falls off the edge of the world and hits bottom? LOL! Thanks for the input.
John
Drew
01-04-2004 16:51:22
 Re: More rollcage questions in reply to john needs a cage, 01-04-2004 16:11:21
The SFI website has the specs for a rollcage, but they charge $35.00 to get them. For under 6000lbs, you would want the SFI 47.2 spec. For more info, go to www.sfifoundation.com and click on "chassis specs" Hope this helps, Drew
