cam
champspa
01-04-2004 15:43:15
what's the lift on a cam in a farmall 450 mine is .405 is this near normal?
farmall
01-05-2004 06:48:30
 Re: cam in reply to champspa, 01-04-2004 15:43:15
You can't be measuring it right. I just checked a stock one i have laying here and i got .262 lift. My cam appears to be in good cond. Unless you are checking lift at valve. Then you need to figure in the rocker ratio (1.65 to 1) .405 divided by 1.65 = .245 plus .017 rocker clearence = .262 Hope this helps.
champspa
01-05-2004 13:07:27
 Re: Re: cam in reply to farmall, 01-05-2004 06:48:30
yea I measured the amount the valve moved down it's .405 is the normal?
farmall
01-06-2004 06:49:14
 Re: Re: Re: cam in reply to champspa, 01-05-2004 13:07:27
Yes this is normal. Glad to help.
champspa
01-05-2004 13:20:18
thanks for the info Farmall
