BORING JD 70 GAS to 6.125
Old Joe
01-01-2004 09:45:41
Just wondering if anyone has bored a 70 gas block to 6.125 and used standard model G pistons or what would the max over bore be for the 70.
Thanks Ole Joe
buickanddeere
01-01-2004 20:57:14
 Re: BORING JD 70 GAS to 6.125 in reply to Old Joe, 01-01-2004 09:45:41
There are some previous posts here on this area. Can be done but the cylinder walls are getting skinny. Go with a aluminium piston and 6.5-8.0 to 1 compression to run on pump gas. Blend the valve bowls smooth,three angle valve job and all fuel valves machined to a nail head shape plus a cam from Roberts. Makes a stout machine.
a puller
01-03-2004 08:42:20
 Re: Re: BORING JD 70 GAS to 6.125 in reply to buickanddeere, 01-01-2004 20:57:14
what do you mean by nailhead shape? thanks alot
buickanddeere
01-03-2004 09:01:48
 Re: Re: Re: BORING JD 70 GAS to 6.125 in reply to a puller, 01-03-2004 08:42:20
Valve looks like a nail. Metal is removed from the back of the valve to make more room for airflow through the port. Valve has to be made of good stuff and spring pressures modest. Makes torque however.
