sleeving a B block
jdtruble
12-29-2003 18:18:00
I am looking to Bore and sleeve a 1940 B to put in newer pistons(the 4 11/16 size and go .09 over that )the wall thickness will be about .125 after I bore it will this be to thin? If so where can I get sleeves for this.
Brian
12-30-2003 07:59:16
 Re: sleeving a B block in reply to jdtruble, 12-29-2003 18:18:00
You can bore it that big without sleeves. I put the same bore on my B and it worked just fine. Hope this helps
jdtruble
12-31-2003 05:04:33
 Re: Re: sleeving a B block in reply to Brian, 12-30-2003 07:59:16
What year of B did you do that to? right know mine is stock bore for 1940 and that is 4.5 dia bore. I would like to go to about 4.777 dia bore
is that what you did?
farmall
12-30-2003 07:06:19
.125 wall is ok only if they are ductile iron.
Cast would be to weak. Try Darton Sleeve Co. They advertise in the Hook Mag. They will make sleeves to your print. Hope this helps. PS the quality is excellent and not to pricey.
