U moline weight
Kenn y
12-29-2003 15:54:34
I have a U and was wondering how light you can get them.I have removed the pto,belt pulley and put on pressed steel any other ideas? Also what combination would get about 100hp. THANKS
Spudhead 11
01-19-2004 15:36:00
 Re: U moline weight in reply to Kenn y , 12-29-2003 15:54:34
I took a 6250 lb MM 5 Star and it weighs 4850 without driver now, anything is possible.
Mopower
01-04-2004 14:51:37
I have a 47 U I pull in 5500. It has cast centers but no belt pulley or hydraulics. A 403 power unit is going in it. A healthy G motor will do 100 hp easy. Good Luck!!!!!
dave
12-31-2003 14:25:54
What are the step you guy out there are going to get this tractor down in the 4500 lb class with 18.4 and what is the money you are spending is it cheap or is it alot of money to do.we are just start to liten up ours
Wendel
12-31-2003 03:57:57
My 1949 UTS goes 4250 without driver.I can't do very good on it. Put my 110 pound daughter on it and hang some weight out front does much better.
minnie ub
12-30-2003 15:40:47
i,ve seen u's that can get into 4500 lb class but he used some alumnium.ought to get in 5000 lb class. go to weld on hubs. take anything you don't need off 5or 10 pounds add up. we can get our ub in 5000 class and add weight with 15.5 but with 18.4 we can't get our 200lbs of movable weight.ub's are liter than u's.we don,t use any alumnium. L.W.'s engine combo is a good one for 100hp.
Kenny
12-30-2003 15:00:34
Hey guys what are you doing to get that light.Mine weighs about 5000 right now,would like to get it in 4500. Thanks
JDlover
12-30-2003 13:30:57
You could use a different head.
a puller
12-29-2003 17:54:14
you can get it to around 4800 w/o alot of aluminum. A good combo would be m5jugs and pistons and a G(6") crank offset ground to U rods. Use some 4210 heads and that would be about 100 - 110 hp @ 540
LW
12-29-2003 16:03:43
Go with the later 4 5/8 bore blocks and 6"(G) Crank and 4232 heads, good carb and ign 100hp at 1200rpm no problem
au two
12-29-2003 19:54:43
 Re: Re: U moline weight in reply to LW, 12-29-2003 16:03:43
my u is at 4150 no aluminum
LW
12-30-2003 06:38:48
 Re: Re: Re: U moline weight in reply to au two, 12-29-2003 19:54:43
I put one in the 4200 with alum. weight brackets steel wheels w/18.4 X 38 180lb driver so it was right at 4000lb could have got 200lbs more off..
Jerry
12-30-2003 16:22:15
 Re: Re: Re: Re: U moline weight in reply to LW, 12-30-2003 06:38:48
I see in a previous post that 4 5/8 x 6 is 100 horse but my G is stock at that spec. and the nebraska test has them rated at 74 horse. I know that cam, manifold, larger valves and carb. could will get you over 100 horse.
LW
12-30-2003 20:33:32
 Re: Re: Re: Re: Re: U moline weight in reply to Jerry, 12-30-2003 16:22:15
Notice I said 4232 heads , but I built a 403 .030 over with a little carb. work and cam stock manifolds and stock rpm did right at 100hp the 4232 took it around 112-114hp NOTE: This is not at the factory 6 to 1 compression.
