Turbo on a M farmall
oldman70
10-14-2001 16:50:08
can i put a turbo on a M? and if so will the main caps hold the crank in or would i need a gertal to help hold the crank in???....what else would i have to do if I was to put a turbo on it???
thanks
Dale13
10-15-2001 12:06:17
 Re: turbo on a M farmall in reply to oldman70, 10-14-2001 16:50:08
Contact Caledonia Diesel in Caledonia NY,they did one for a guy and he won a lot of pulls till he got caught in tech inspection.
redhead
10-15-2001 06:21:38
The three main bearing lower end will become weak at some point. If you push it far enough, the center main will be over stressed and you will see cracks on the outside of the block in this area. A five main diesel block and crank would be stronger. The best thing to do is get some advise for a good engine builder. Keep in mind: the engine needs strength not high rpms, high compression and turbos generally don't mix, air flow in and out of the engine is VERY important-this means manifolds, ports, valves, cam and the turbo runners need careful thought, the turbo must be sized correctly to make the desired boost from the amount of exhaust cfm at the given engine rpm.
Take your time and plan it all out before you start. It could be a fun project! Good luck.
Very Good Advice
10-16-2001 16:01:41
 Re: Re: turbo on a M farmall in reply to redhead, 10-15-2001 06:21:38
Redhead wrote a very intelligent reply. I agree with it. There a several books on the market that would be of help too. Glad to see this discussion.
Steve
10-16-2001 18:33:57
 Re: Re: Re: turbo on a M farmall in reply to Very Good Advice, 10-16-2001 16:01:41
Back about 1977-198+ Pete Lusseto of Bridgeport Nebraska ran an M in the Superstock class twin turboed did really well...owns a machine shop there,still going. They had a hot running and fun to watch tractor. I'm sure they could give you lots of advise and maybe even parts. I live in Oregon now so I don'thave a phone # for him. You should be able to find through directory assistance.
Steve
